Philco 38-4
In this case, should be no problem. Sometimes hard to tell if it's original or a later change. Not uncommon for different runs, or even within runs to have changes in specs with no accompanying documentation.
Philco 38-4 - by rickd - 08-04-2013, 03:11 PM
RE: Philco 38-4 - by codefox1 - 08-05-2013, 11:53 AM
RE: Philco 38-4 - by rickd - 08-05-2013, 02:17 PM
There are currently 7871 online users. [Complete List]
» 3 Member(s) | 7868 Guest(s)
