O man now I've done it, Philco 37-116
That's pretty much what mine is.
It has brass bearings on the 2 sides imbedded in the wood frame surrounding the chassis.
This frame rotates about the brass bearings and is suspended between a couple A frames.
Works great.
murf
RE: O man now I've done it, Philco 37-116 - by murf - 08-05-2013, 02:33 PM
There are currently 10028 online users. [Complete List]
» 3 Member(s) | 10025 Guest(s)
