O man now I've done it, Philco 37-116
I don't know if this helps but I just got an empty Majestic Model 92 cabinet shipped by Greyhound Express. From Michigan to NC $68 bucks, 4 days. Arrived in great condition. Total weight about 85 lbs.
Good luck,
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
RE: O man now I've done it, Philco 37-116 - by PhilcoMike - 08-06-2013, 12:18 PM
There are currently 9612 online users. [Complete List]
» 3 Member(s) | 9609 Guest(s)
