Philco Beam of Light 41-608
After many trys and a few hundred dollars I can say I have a working BOL
Philco Beam of Light 41-608 - by Guest - 03-10-2006, 07:02 PM
Photoelectric pickup - by Doug Houston - 03-12-2006, 12:19 AM
philco 41-608 - by Guest - 03-12-2006, 04:38 AM
[No subject] - by Guest - 08-31-2006, 10:46 AM
Philco BOL 41-608 - by Guest - 02-26-2008, 12:56 AM
[No subject] - by gary rabbitt - 02-26-2008, 02:41 PM
[No subject] - by Ron Ramirez - 02-26-2008, 06:34 PM
