Chassis screws for 89B
Of course , i'm not an expert on these Radios...But considering how old it is and the fact that the US didn't take up metric until much later, the 1/4" screw would be my guess. Also, didn't Ron say the #14 would be a little tight at first? That tells me that the US size type would probably be correct as the US and Metrics sizes are inbetween each other.
Chassis screws for 89B - by BrendaAnnD - 08-04-2013, 11:28 AM
RE: Chassis screws for 89B - by Ron Ramirez - 08-05-2013, 05:40 AM
RE: Chassis screws for 89B - by Steve Davis - 08-06-2013, 06:52 PM
RE: Chassis screws for 89B - by Warren - 08-06-2013, 07:11 PM
RE: Chassis screws for 89B - by Arran - 08-07-2013, 12:29 AM
RE: Chassis screws for 89B - by Warren - 08-07-2013, 03:40 PM
RE: Chassis screws for 89B - by BrendaAnnD - 08-07-2013, 09:37 PM
RE: Chassis screws for 89B - by Warren - 08-07-2013, 10:57 PM
RE: Chassis screws for 89B - by Steve Davis - 08-08-2013, 02:13 AM
There are currently 10610 online users. [Complete List]
» 3 Member(s) | 10607 Guest(s)
