37-624 Mail Filter Cap 34 is NON-POLARIZED
Steve D Wrote:Higher value film capacitors are available from many sources such as ASC capacitors:
http://www.ascapacitor.com/Products/x663f.htm
Steve D
Thanks. It really irks me that my favorite vendor (Mouser) no longer stocks ASC capacitors. It appears that JustRadios in Canada stocks a few. The high voltage ones are needed for restoring TV sets, such as the 7" ones using electrostatic deflection. Allied has them, but they have a high minimum order. I have not checked DigiKey and other sources.
Good tip. I still would like to know IF I need to use non-polarized capacitors for filters in this radio, and WHY! I just looked at another 6 volt set in my collection (37-34) and it does NOT use non-polarized caps.
Dave
[No subject] - by Chuck Schwark - 02-25-2008, 09:28 PM
[No subject] - by davemc - 02-26-2008, 07:13 AM
[No subject] - by Ron Ramirez - 02-26-2008, 07:59 AM
[No subject] - by davemc - 02-26-2008, 08:13 AM
[No subject] - by Steve D - 02-26-2008, 12:38 PM
[No subject] - by davemc - 02-26-2008, 01:06 PM
[No subject] - by davemc - 03-03-2008, 06:07 PM
[No subject] - by Ron Ramirez - 03-03-2008, 11:10 PM
[No subject] - by davemc - 03-14-2008, 05:25 PM
[No subject] - by Ron Ramirez - 03-20-2008, 10:58 PM
The speaker table error?
Philco 70 antenna lead
There are currently 5996 online users. [Complete List]
» 1 Member(s) | 5995 Guest(s)
