38-7 with 6L6
A tube does not "put a load" on the transformer. The transformer (or rather the load, that is the speaker's voice coil, reflected by transformer) loads the tube.
The tube is the source and the load is, well, the load.
38-7 with 6L6 - by Larry Morrow - 08-07-2013, 07:12 PM
RE: 38-7 with 6L6 - by morzh - 08-07-2013, 07:53 PM
RE: 38-7 with 6L6 - by Larry Morrow - 08-07-2013, 09:46 PM
RE: 38-7 with 6L6 - by morzh - 08-07-2013, 10:19 PM
RE: 38-7 with 6L6 - by Larry Morrow - 08-07-2013, 10:28 PM
RE: 38-7 with 6L6 - by codefox1 - 08-07-2013, 10:57 PM
RE: 38-7 with 6L6 - by Mondial - 08-07-2013, 11:57 PM
RE: 38-7 with 6L6 - by Larry Morrow - 08-08-2013, 12:26 AM
RE: 38-7 with 6L6 - by Larry Morrow - 08-08-2013, 12:20 PM
There are currently 8807 online users. [Complete List]
» 1 Member(s) | 8806 Guest(s)
