37-620 Restoration
While waiting on parts, I tried painting a tube shield. Then it occurred to me that the paint prevents a good ground through the holding clamps. Is this an issue? How do you guys handle this? Just not paint the bottom where the clamp is?
tks, Vic
http://s1275.photobucket.com/user/vgibso...6.jpg.html
37-620 Restoration - by Vic Gibson - 08-08-2013, 11:16 AM
RE: 37-620 Restoration - by murf - 08-08-2013, 11:39 AM
RE: 37-620 Restoration - by Vic Gibson - 08-08-2013, 11:56 AM
RE: 37-620 Restoration - by jerryhawthorne - 08-08-2013, 03:33 PM
RE: 37-620 Restoration - by Ron Ramirez - 08-08-2013, 04:20 PM
There are currently 9889 online users. [Complete List]
» 1 Member(s) | 9888 Guest(s)
