38-7 with 6L6
Replaced the 6L6 with the correct 6F6and it seems to play as well as it did with the 6L6.
However....found that the 1st audio had been changed from a 6K5 to a 6R7, and that set wouldn't play with a 6K5 in place. Put the 6R7 back in and it played like a champ. This radio had a very good recap in the not too distant past (before me) and even the 6k5 socket doesn't appear to have had the wiring changed.
Could this have been a factory modification ?
38-7 with 6L6 - by Larry Morrow - 08-07-2013, 07:12 PM
RE: 38-7 with 6L6 - by morzh - 08-07-2013, 07:53 PM
RE: 38-7 with 6L6 - by Larry Morrow - 08-07-2013, 09:46 PM
RE: 38-7 with 6L6 - by morzh - 08-07-2013, 10:19 PM
RE: 38-7 with 6L6 - by Larry Morrow - 08-07-2013, 10:28 PM
RE: 38-7 with 6L6 - by codefox1 - 08-07-2013, 10:57 PM
RE: 38-7 with 6L6 - by Mondial - 08-07-2013, 11:57 PM
RE: 38-7 with 6L6 - by Larry Morrow - 08-08-2013, 12:26 AM
RE: 38-7 with 6L6 - by Larry Morrow - 08-08-2013, 12:20 PM
There are currently 10462 online users. [Complete List]
» 2 Member(s) | 10460 Guest(s)
