37-620 Restoration
The shields were originally tin plated.
I have found that the Krylon Satin Nickel does conduct. I've sprayed some shields with Satin Nickel and not had any issues of the shields losing their effectiveness.
37-620 Restoration - by Vic Gibson - 08-08-2013, 11:16 AM
RE: 37-620 Restoration - by murf - 08-08-2013, 11:39 AM
RE: 37-620 Restoration - by Vic Gibson - 08-08-2013, 11:56 AM
RE: 37-620 Restoration - by jerryhawthorne - 08-08-2013, 03:33 PM
RE: 37-620 Restoration - by Ron Ramirez - 08-08-2013, 04:20 PM
There are currently 9796 online users. [Complete List]
» 3 Member(s) | 9793 Guest(s)
