42-350 antenna
Thanks for all the replies. Arran, I suspected it might be small Phillips head screws that secured the antenna, as my 48-482, which appears to be a close cousin (or perhaps younger brother) to this radio has the same antenna and is secured with them.
42-350 antenna - by radiodocs - 08-06-2013, 05:25 PM
RE: 42-350 antenna - by Eric Adams - 08-06-2013, 11:50 PM
RE: 42-350 antenna - by Arran - 08-07-2013, 12:22 AM
RE: 42-350 antenna - by Jim Dutridge - 08-07-2013, 08:42 AM
RE: 42-350 antenna - by radiodocs - 08-08-2013, 05:12 PM
There are currently 9644 online users. [Complete List]
» 3 Member(s) | 9641 Guest(s)
