coil 32 - 1360
Hi All;
I got the coil from "things of the past" as part of my coil order to get the minimum order.. Both Gary and I have no idea what it was part of, I have two others that I don't even have a number for.. Just thought I would ask, If anyone recognized this number.. I didn't want to just completely tear out the wire, If I though I could use it for something.. Same with the other two, I will eventually measure the resistances on the other two, to see if they match anything I have documentation on.. All three were used "Junk" coil forms.. And this one was the only one with a number.. I am very Happy with the Service and what all I got from Gary, He is and was very Helpfull.. I would recemend His site to anyone..
THANK YOU Marty
coil 32 - 1360 - by marty - 08-09-2013, 06:51 PM
RE: coil 32 - 1360 - by codefox1 - 08-10-2013, 02:48 PM
RE: coil 32 - 1360 - by marty - 08-10-2013, 03:05 PM
RE: coil 32 - 1360 - by marty - 08-10-2013, 04:43 PM
There are currently 8633 online users. [Complete List]
» 2 Member(s) | 8631 Guest(s)
