information required
Ummm...Randal..actually the reverse is true - power transformers designed to run on 25 cycle AC will work just fine on 60 cycles. It is the transformer designed for 60 cycle AC that will burn up if operated on 25 cycle AC.
information required - by Guest - 02-25-2008, 01:25 PM
[No subject] - by gary rabbitt - 02-25-2008, 05:30 PM
[No subject] - by Ron Ramirez - 02-25-2008, 06:43 PM
[No subject] - by Texasrocker - 02-27-2008, 12:03 AM
[No subject] - by Ron Ramirez - 02-27-2008, 07:32 AM
[No subject] - by Guest - 02-27-2008, 01:18 PM
[No subject] - by Guest - 02-27-2008, 01:24 PM
[No subject] - by Ron Ramirez - 02-27-2008, 06:32 PM
Philco 91 Restore Code ??
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
There are currently 3256 online users. [Complete List]
» 4 Member(s) | 3252 Guest(s)
AvatarAvatarAvatarAvatar
