49-906 FM hum
I just finished my 49-906. Replaced all caps, out of range resistors and a few tubes. Alignment was done also.
AM is good and strong-no hum. FM picks up a few stations but has a hum all across the dial. It does almost go away when tuned to a station.
What did I miss?
http://www.nostalgiaair.org/PagesByModel...013675.pdf
Eric
The Villages, FL
49-906 FM hum - by Eric Adams - 08-11-2013, 12:21 PM
RE: 49-906 FM hum - by Mondial - 08-11-2013, 12:54 PM
RE: 49-906 FM hum - by Eric Adams - 08-11-2013, 01:48 PM
RE: 49-906 FM hum - by Eric Adams - 08-11-2013, 03:16 PM
There are currently 9197 online users. [Complete List]
» 3 Member(s) | 9194 Guest(s)
