Anyone ever heard of an Imperial radio?
Looks like this radio would be nicknamed "Cyclopes". Icon_smile
RE: Anyone ever heard of an Imperial radio? - by wa2ise - 08-11-2013, 09:15 PM
There are currently 2090 online users. [Complete List]
» 1 Member(s) | 2089 Guest(s)
