Restoring 38-12 no audio
I am restoring a 38-12. I have replaced all the caps and checked all the tubes. There is no audio at all. Would the output transformer located on top of the speaker be the problem? What is the best way to test the transformer? Anything else I should check?
Thanks.
Restoring 38-12 no audio - by cwirth - 08-11-2013, 09:17 PM
RE: Restoring 38-12 no audio - by marty - 08-11-2013, 09:52 PM
RE: Restoring 38-12 no audio - by Arran - 08-12-2013, 05:53 AM
RE: Restoring 38-12 no audio - by Groundhog74 - 08-13-2013, 09:45 AM
RE: Restoring 38-12 no audio - by morzh - 08-13-2013, 10:18 AM
There are currently 9906 online users. [Complete List]
» 1 Member(s) | 9905 Guest(s)
