information required
gary rabbitt Wrote:Hello Mario and welcome.
Could you please post a photo of your set, or if you're uable email t to me, and I will post it. That number does not sound familiar as a model number. With a photo someone will surely know the model.
From there can possibly find someone in your area to do the work, and what to expect the average costs to be for restoration.
Take care,
Gary.
I do not know if I'm using the right way to reply but let me try. I do have few photos that might help but I do not know how to proceed to send them?
information required - by Guest - 02-25-2008, 01:25 PM
[No subject] - by gary rabbitt - 02-25-2008, 05:30 PM
[No subject] - by Ron Ramirez - 02-25-2008, 06:43 PM
[No subject] - by Texasrocker - 02-27-2008, 12:03 AM
[No subject] - by Ron Ramirez - 02-27-2008, 07:32 AM
[No subject] - by Guest - 02-27-2008, 01:18 PM
[No subject] - by Guest - 02-27-2008, 01:24 PM
[No subject] - by Ron Ramirez - 02-27-2008, 06:32 PM
