Stewart-Warner Cabinet paint
I think the paint and varnish remover sold under the Kleenstrip brand might have methylene chloride in it. As for repainting it alkyd enamel spray paint always worked for me, you can also use the special plastic paint too but that was really designed to stick to polyethylene, Bakelite doesn't have that bonding problem so much.
Stewart-Warner Cabinet paint - by Eric - 08-08-2013, 03:53 PM
RE: Stewart-Warner Cabinet paint - by Warren - 08-08-2013, 06:01 PM
RE: Stewart-Warner Cabinet paint - by Arran - 08-09-2013, 05:13 AM
RE: Stewart-Warner Cabinet paint - by Eric - 08-11-2013, 08:53 AM
RE: Stewart-Warner Cabinet paint - by Arran - 08-12-2013, 09:46 AM
RE: Stewart-Warner Cabinet paint - by Eric - 08-12-2013, 02:19 PM
RE: Stewart-Warner Cabinet paint - by Arran - 08-12-2013, 08:02 PM
RE: Stewart-Warner Cabinet paint - by Eric - 08-13-2013, 12:53 PM
There are currently 10195 online users. [Complete List]
» 2 Member(s) | 10193 Guest(s)
