Need help with Philco 620
Ok, I've been working on it. This is going to be difficult for me to describe because I may not know the correct terminology in order to explain to you exactly what I've found.... but here goes..
This radio has had previous work done on it, so, assuming the mistake lies in the previous work, I started tracing things according to the schematic. I noticed that there is a connection between one of the 8mf electrolytics and part number 33-3222 (70 on the schematic), (also, this is correct according to the schematic)... well, a wire had been added that connected the ground end of the same 8mf cap to the same joint on 33-3222. To me, that represents a short! .. So, I removed that wire and voila! I have full volume and the tone control now works on all three settings.
The only problem now, is that there is a hum all the way across the dial. It isn't terribly bad, it almost sounds like interference.. but it isn't right. Any ideas?
Need help with Philco 620 - by Jamie - 08-09-2013, 03:16 PM
RE: Need help with Philco 620 - by marty - 08-09-2013, 05:44 PM
RE: Need help with Philco 620 - by Phlogiston - 08-09-2013, 06:28 PM
RE: Need help with Philco 620 - by morzh - 08-09-2013, 06:50 PM
RE: Need help with Philco 620 - by Jamie - 08-09-2013, 07:28 PM
RE: Need help with Philco 620 - by Phlogiston - 08-09-2013, 08:13 PM
RE: Need help with Philco 620 - by Jamie - 08-09-2013, 08:32 PM
RE: Need help with Philco 620 - by Phlogiston - 08-09-2013, 08:48 PM
RE: Need help with Philco 620 - by Jamie - 08-09-2013, 09:12 PM
RE: Need help with Philco 620 - by Jamie - 08-14-2013, 09:44 AM
RE: Need help with Philco 620 - by Phlogiston - 08-14-2013, 10:02 AM
RE: Need help with Philco 620 - by Jamie - 08-14-2013, 12:22 PM
RE: Need help with Philco 620 - by Arran - 08-14-2013, 07:57 PM
RE: Need help with Philco 620 - by Jamie - 08-15-2013, 08:47 AM
RE: Need help with Philco 620 - by marty - 08-15-2013, 02:37 PM
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
There are currently 2545 online users. [Complete List]
» 1 Member(s) | 2544 Guest(s)
