The Emerson is singing now
#56
Well, it is five evenings and 68 bucks in goods and shipment later too!
One evening went to clean the thing.
Another is to figure out the caps to order from the sch (like I said mostly a wasted effort as the values did not match, sometimes grossly).
The third was to unsolder the burnt coil and to draw the sketch of its connection.
The fourth and fifth went to recapping.
And now we wait for the ballast to come. I hope it will take just one more evening.
The Emerson is singing now - by morzh - 07-22-2013, 10:07 PM
RE: An Emerson like this one - by BrendaAnnD - 07-23-2013, 02:48 AM
RE: An Emerson like this one - by morzh - 07-23-2013, 07:17 AM
RE: An Emerson like this one - by Arran - 07-23-2013, 08:08 AM
RE: An Emerson like this one - by morzh - 07-23-2013, 08:33 AM
RE: An Emerson like this one - by morzh - 07-23-2013, 08:37 AM
RE: An Emerson like this one - by Phlogiston - 07-23-2013, 09:36 AM
RE: An Emerson like this one - by morzh - 07-23-2013, 03:37 PM
RE: An Emerson like this one - by Phlogiston - 07-23-2013, 05:06 PM
RE: An Emerson like this one - by Arran - 07-24-2013, 04:53 AM
RE: An Emerson like this one - by morzh - 07-24-2013, 01:44 PM
RE: An Emerson like this one - by Phlogiston - 07-24-2013, 02:23 PM
RE: An Emerson like this one - by morzh - 07-24-2013, 08:26 PM
RE: An Emerson like this one - by Phlogiston - 07-24-2013, 09:09 PM
RE: An Emerson like this one - by Arran - 07-26-2013, 11:36 AM
RE: An Emerson like this one - by morzh - 07-26-2013, 06:23 PM
RE: An Emerson like this one - by morzh - 07-26-2013, 07:39 PM
RE: An Emerson like this one - by Paul Philco322 - 07-26-2013, 08:50 PM
RE: An Emerson like this one - by morzh - 07-26-2013, 09:27 PM
RE: An Emerson like this one - by morzh - 07-26-2013, 09:44 PM
RE: An Emerson like this one - by morzh - 07-26-2013, 10:00 PM
RE: An Emerson like this one - by morzh - 07-26-2013, 10:08 PM
RE: An Emerson like this one - by Mondial - 07-26-2013, 10:19 PM
RE: An Emerson like this one - by Phlogiston - 07-26-2013, 10:20 PM
RE: An Emerson like this one - by morzh - 07-27-2013, 01:06 PM
RE: An Emerson like this one - by BrendaAnnD - 07-27-2013, 04:02 PM
RE: An Emerson like this one - by BrendaAnnD - 07-27-2013, 04:16 PM
RE: An Emerson like this one - by morzh - 07-28-2013, 12:31 AM
RE: An Emerson like this one - by BrendaAnnD - 07-28-2013, 04:18 AM
RE: An Emerson like this one - by morzh - 07-28-2013, 09:11 PM
RE: An Emerson like this one - by BrendaAnnD - 07-28-2013, 10:11 PM
RE: An Emerson like this one - by morzh - 07-29-2013, 09:17 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 10:05 AM
RE: An Emerson like this one - by BrendaAnnD - 07-30-2013, 10:51 AM
RE: An Emerson like this one - by morzh - 07-30-2013, 03:28 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 08:18 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 08:33 PM
RE: An Emerson like this one - by BrendaAnnD - 07-30-2013, 09:06 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 09:41 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 09:56 PM
RE: An Emerson like this one - by BrendaAnnD - 07-30-2013, 10:43 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 11:11 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 11:29 PM
RE: An Emerson like this one - by Phlogiston - 07-31-2013, 12:25 AM
RE: An Emerson like this one - by Ron Ramirez - 07-31-2013, 05:27 AM
The Emerson - it is singing now. - by morzh - 07-31-2013, 10:57 AM
RE: An Emerson like this one - by Phlogiston - 07-31-2013, 04:28 PM
RE: An Emerson like this one - by BrendaAnnD - 07-31-2013, 07:10 PM
RE: An Emerson like this one - by Phlogiston - 08-01-2013, 01:09 AM
RE: An Emerson like this one - by BrendaAnnD - 08-01-2013, 02:30 AM
RE: An Emerson like this one - by morzh - 08-01-2013, 09:41 AM
RE: An Emerson like this one - by Gene Pederson - 08-06-2013, 05:39 PM
RE: An Emerson like this one - by morzh - 08-13-2013, 11:41 PM
RE: An Emerson like this one - by Paul Philco322 - 08-14-2013, 09:10 PM
RE: An Emerson like this one - by morzh - 08-15-2013, 01:54 PM
RE: An Emerson like this one - by Paul Philco322 - 08-15-2013, 02:28 PM
RE: The Emerson is singing now - by morzh - 08-17-2013, 10:15 PM
RE: The Emerson is singing now - by morzh - 08-18-2013, 11:56 PM
RE: The Emerson is singing now - by morzh - 09-16-2013, 10:43 AM
RE: The Emerson is singing now - by Radioroslyn - 09-16-2013, 02:21 PM
RE: The Emerson is singing now - by morzh - 09-16-2013, 03:23 PM
There are currently 2047 online users. [Complete List]
» 2 Member(s) | 2045 Guest(s)
