Question about model 116
Chuck Schwark Wrote:Appears heavily modified for who knows/knew what.....knobs, switches, an extra chassis bolted to the cabinet interior with holes thru the wood side. Yikes!
I saw this one as well, not to buy, but I shook my head in disbelief with that awful modification that took place. Good move for you not to buy. What I cannot believe is the going price now. I smell a hoax.
73 de,
Gary/N9VU
Question about model 116 - by Guest - 02-26-2008, 02:31 PM
[No subject] - by Chuck Schwark - 02-26-2008, 02:39 PM
[No subject] - by Guest - 02-26-2008, 07:30 PM
[No subject] - by n9vu - 02-28-2008, 12:00 AM
[No subject] - by Ron Ramirez - 02-28-2008, 12:18 AM
Philco 91 Tuning Condenser
There are currently 10154 online users. [Complete List]
» 3 Member(s) | 10151 Guest(s)
