Adjusting the 66 compensators
Yep, all tube shields are in place and are making good contact with the chassis. Now, the only thing thats not "original" , or as close as possible, is the placement of the electrolytic #49. Its placed between the terminal board where resistor #47 and resistor #15 are tied to and the negative end is attached to the ground terminal thats rivoted to the socket of the 6A7 tube.
Adjusting the 66 compensators - by Jim Dutridge - 07-08-2013, 04:00 PM
RE: Adjusting the 66 compensators - by klondike98 - 07-08-2013, 05:22 PM
RE: Adjusting the 66 compensators - by klondike98 - 07-10-2013, 07:04 PM
RE: Adjusting the 66 compensators - by Jim Dutridge - 08-15-2013, 05:57 PM
RE: Adjusting the 66 compensators - by Arran - 08-16-2013, 07:46 PM
RE: Adjusting the 66 compensators - by klondike98 - 08-18-2013, 07:58 PM
There are currently 10358 online users. [Complete List]
» 3 Member(s) | 10355 Guest(s)
