Adjusting the 66 compensators
Possible gassy 78 tube? That can cause oscillation as well.
Make sure all grounds are good and do not have any rust or otherwise high resistance paths to ground.
Adjusting the 66 compensators - by Jim Dutridge - 07-08-2013, 04:00 PM
RE: Adjusting the 66 compensators - by klondike98 - 07-08-2013, 05:22 PM
RE: Adjusting the 66 compensators - by klondike98 - 07-10-2013, 07:04 PM
RE: Adjusting the 66 compensators - by Ron Ramirez - 08-15-2013, 09:03 PM
RE: Adjusting the 66 compensators - by Arran - 08-16-2013, 07:46 PM
RE: Adjusting the 66 compensators - by klondike98 - 08-18-2013, 07:58 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
There are currently 1892 online users. [Complete List]
» 5 Member(s) | 1887 Guest(s)
AvatarAvatarAvatarAvatar
