Philco 38-3 That old musty smell..
I did that once too, but lightly crushed the briquets to
expose more surface area to speed up absorption.
Chuck
Philco 38-3 That old musty smell.. - by JROZ - 08-15-2013, 11:56 AM
RE: Philco 38-3 That old musty smell.. - by JROZ - 08-15-2013, 02:17 PM
RE: Philco 38-3 That old musty smell.. - by Arran - 08-15-2013, 10:51 PM
RE: Philco 38-3 That old musty smell.. - by Chuck Schwark - 08-16-2013, 09:16 AM
RE: Philco 38-3 That old musty smell.. - by JROZ - 08-19-2013, 10:22 AM
RE: Philco 38-3 That old musty smell.. - by morzh - 08-24-2013, 10:35 PM
There are currently 10533 online users. [Complete List]
» 3 Member(s) | 10530 Guest(s)
