1963 Admiral record player
[attachment=2308][attachment=2309]I am working on an Admiral record changer. It works great except for the mechanism that is used to select for the record size. I found that a part is broken. See pictures. The thin rod that sticks out is busted off. I think it is suppose to bend around and hook into the top of the size selector. I was wondering if by chance anyone has one that they could send me a picture of this part. Maybe I could make one. Or if someone had the part to sale.
Thanks Bob
1963 Admiral record player - by Bob - 08-16-2013, 08:59 PM
RE: 1963 Admiral record player - by Bob - 08-17-2013, 08:43 AM
RE: 1963 Admiral record player - by Eric T - 08-20-2013, 05:55 PM
RE: 1963 Admiral record player - by Bob - 08-20-2013, 10:12 PM
There are currently 9007 online users. [Complete List]
» 3 Member(s) | 9004 Guest(s)
