Poss. OSC Problems Philco 34
Hi All;
Thank You Arran for Your response.. And yes this is a Battery set.. With a Battery type of Eliminator for its power.. All of the voltages are correct and have been capped to cure any 60 cycle Hum..
I will re check the Grid Caps.. ALL of the Sockets have been replaced with new sockets..
But, (sort of) per Your suggestion I will check all of the Grid connections and make sure that they are wired correctly..
THANK YOU Marty
Poss. OSC Problems Philco 34 - by marty - 08-16-2013, 12:08 AM
RE: Poss. OSC Problems Philco 34 - by BrendaAnnD - 08-16-2013, 02:10 AM
RE: Poss. OSC Problems Philco 34 - by marty - 08-16-2013, 10:16 AM
RE: Poss. OSC Problems Philco 34 - by Arran - 08-16-2013, 07:42 PM
RE: Poss. OSC Problems Philco 34 - by marty - 08-16-2013, 08:37 PM
RE: Poss. OSC Problems Philco 34 - by marty - 08-17-2013, 09:43 PM
RE: Poss. OSC Problems Philco 34 - by marty - 08-17-2013, 10:23 PM
RE: Poss. OSC Problems Philco 34 - by marty - 08-19-2013, 02:48 PM
RE: Poss. OSC Problems Philco 34 - by marty - 08-19-2013, 04:13 PM
RE: Poss. OSC Problems Philco 34 - by marty - 08-26-2013, 01:38 PM
RE: Poss. OSC Problems Philco 34 - by marty - 08-26-2013, 03:12 PM
RE: Poss. OSC Problems Philco 34 - by marty - 08-31-2013, 07:02 PM
RE: Poss. OSC Problems Philco 34 - by marty - 09-02-2013, 10:34 AM
RE: Poss. OSC Problems Philco 34 - by marty - 09-02-2013, 02:28 PM
RE: Poss. OSC Problems Philco 34 - by marty - 09-02-2013, 09:34 PM
New member
Philco 630csx power cord
New member
There are currently 2607 online users. [Complete List]
» 5 Member(s) | 2602 Guest(s)
AvatarAvatarAvatarAvatar
