46-350 Electrolytic Cap Explosion?
Sure looks like pot metal "rot" to me as well. There would be paper fluff all over if it had exploded. Does not even look that swollen either. Some expected age induced swelling (due to increasing leakage and subsequent heating/expansion) may have contributed to the pot metal's demise through cracking and then enevitable pot metal disintegration.
[No subject] - by justlrnin - 02-27-2008, 09:32 PM
[No subject] - by Ron Ramirez - 02-27-2008, 11:44 PM
[No subject] - by Texasrocker - 02-28-2008, 01:32 AM
[No subject] - by Chuck Schwark - 02-28-2008, 09:58 AM
[No subject] - by justlrnin - 02-28-2008, 01:07 PM
[No subject] - by Chuck Schwark - 02-28-2008, 01:15 PM
[No subject] - by justlrnin - 02-28-2008, 03:33 PM
[No subject] - by Guest - 02-28-2008, 06:32 PM
[No subject] - by Texasrocker - 02-29-2008, 03:34 AM
[No subject] - by FStephenMasek - 04-01-2008, 11:33 AM
[No subject] - by justlrnin - 04-01-2008, 12:35 PM
[No subject] - by Alan Douglas - 04-01-2008, 08:19 PM
[No subject] - by FStephenMasek - 04-02-2008, 10:42 AM
[No subject] - by planigan - 04-03-2008, 12:38 AM
[No subject] - by exray - 04-03-2008, 07:37 AM
[No subject] - by justlrnin - 04-03-2008, 12:15 PM
[No subject] - by planigan - 04-03-2008, 11:46 PM
[No subject] - by planigan - 04-04-2008, 07:54 PM
Philco 91 Tuning Condenser
There are currently 8313 online users. [Complete List]
» 2 Member(s) | 8311 Guest(s)
