Need Help Reading a Schematic
I'm still trying to solve the problem of my Philco 620. It has a terrible hum. The radio was previously repaired and I've corrected a few mistakes.
There are three electrolytic caps - (two 8mf and one 16mf). Right now, all three are grounded to the chassis, because that's how they were when I got it. I think this is wrong and it's the source of my hum.
When I look at the schematic, I see the 16mf (part no 52) grounded to chassis, but the two 8mf (part no 67) grounds go somewhere else. Am I correct? And if so, where do I run the ground from the two 8mf caps?
http://www.nostalgiaair.org/PagesByModel...013804.pdf
Thanks
Need Help Reading a Schematic - by Jamie - 08-17-2013, 07:25 AM
RE: Need Help Reading a Schematic - by Jamie - 08-17-2013, 11:00 PM
RE: Need Help Reading a Schematic - by morzh - 08-17-2013, 11:14 PM
RE: Need Help Reading a Schematic - by Jamie - 08-17-2013, 11:24 PM
RE: Need Help Reading a Schematic - by codefox1 - 08-18-2013, 10:57 AM
RE: Need Help Reading a Schematic - by morzh - 08-18-2013, 11:05 AM
RE: Need Help Reading a Schematic - by Jamie - 08-18-2013, 12:13 PM
RE: Need Help Reading a Schematic - by Jamie - 08-18-2013, 06:53 PM
RE: Need Help Reading a Schematic - by morzh - 08-18-2013, 08:21 PM
RE: Need Help Reading a Schematic - by Arran - 08-18-2013, 10:16 PM
RE: Need Help Reading a Schematic - by Jamie - 08-19-2013, 08:18 AM
There are currently 5566 online users. [Complete List]
» 1 Member(s) | 5565 Guest(s)
