46-350 Electrolytic Cap Explosion?
Nothing terribly wrong; the Model 46-350 is a hot-chassis type set. Be sure to use your iso transformer!
Chuck
[No subject] - by justlrnin - 02-27-2008, 09:32 PM
[No subject] - by Ron Ramirez - 02-27-2008, 11:44 PM
[No subject] - by Texasrocker - 02-28-2008, 01:32 AM
[No subject] - by Chuck Schwark - 02-28-2008, 09:58 AM
[No subject] - by justlrnin - 02-28-2008, 01:07 PM
[No subject] - by Chuck Schwark - 02-28-2008, 01:15 PM
[No subject] - by justlrnin - 02-28-2008, 03:33 PM
[No subject] - by Guest - 02-28-2008, 06:32 PM
[No subject] - by Texasrocker - 02-29-2008, 03:34 AM
[No subject] - by FStephenMasek - 04-01-2008, 11:33 AM
[No subject] - by justlrnin - 04-01-2008, 12:35 PM
[No subject] - by Alan Douglas - 04-01-2008, 08:19 PM
[No subject] - by FStephenMasek - 04-02-2008, 10:42 AM
[No subject] - by planigan - 04-03-2008, 12:38 AM
[No subject] - by exray - 04-03-2008, 07:37 AM
[No subject] - by justlrnin - 04-03-2008, 12:15 PM
[No subject] - by planigan - 04-03-2008, 11:46 PM
[No subject] - by planigan - 04-04-2008, 07:54 PM
There are currently 5882 online users. [Complete List]
» 2 Member(s) | 5880 Guest(s)
