Adjusting the 66 compensators
Well, every 78 I tried either made matters worse or had little effect at all. Next will be to try different 75's or maybe a combination of the 75/78's. If that fails then I'll redo the grounds.
Arran, klondike98 was kind enough to pass along a tool he made for adjusting these 1/4" compensators. Works very well.
Adjusting the 66 compensators - by Jim Dutridge - 07-08-2013, 04:00 PM
RE: Adjusting the 66 compensators - by klondike98 - 07-08-2013, 05:22 PM
RE: Adjusting the 66 compensators - by klondike98 - 07-10-2013, 07:04 PM
RE: Adjusting the 66 compensators - by Arran - 08-16-2013, 07:46 PM
RE: Adjusting the 66 compensators - by Jim Dutridge - 08-17-2013, 11:54 AM
RE: Adjusting the 66 compensators - by klondike98 - 08-18-2013, 07:58 PM
There are currently 8418 online users. [Complete List]
» 1 Member(s) | 8417 Guest(s)
