philco 296 cap i.d.
i'm going thru this chassis,caps and resistors 1st. 2 questions;
part number 31,the value on schematic is .5mfd,the part number on the bakelite block crosses to a .05mfd,which is correct?
also,there is a large wire wound resistor about 5 inches long,what is it's value?
thanks,phil
philco 296 cap i.d. - by philco phan - 02-28-2008, 02:16 PM
[No subject] - by Chuck Schwark - 02-28-2008, 02:26 PM
[No subject] - by philco phan - 02-28-2008, 02:58 PM
[No subject] - by philco phan - 02-28-2008, 03:05 PM
[No subject] - by Chuck Schwark - 02-28-2008, 07:08 PM
There are currently 10225 online users. [Complete List]
» 1 Member(s) | 10224 Guest(s)
