Philco 40-130T
Hi, and welcome - we're glad you've joined us! Icon_biggrin
7C5 is listed as a substitute for a 7B5. The 7B5 is more like a 6K6 or 41 in characteristics, while a 7C5 is more like a 6V6. Not exactly the same - grid biasing is different between the two. I think I would go back to the 7B5 if I were you, but no real harm will be done in using a 7C5.
There is no point in buying an entire set of tubes if you don't need them - this just lowers the availability of the other tubes for people who do need them. They aren't making these anymore, folks...so just buy what you need. That's my opinion.
Philco 40-130T - by wireless - 08-17-2013, 07:25 PM
RE: Philco 40-130T - by Ron Ramirez - 08-17-2013, 09:24 PM
RE: Philco 40-130T - by wireless - 08-18-2013, 02:07 AM
RE: Philco 40-130T - by codefox1 - 08-18-2013, 10:45 AM
RE: Philco 40-130T - by Paul Philco322 - 08-18-2013, 11:16 AM
RE: Philco 40-130T - by wireless - 08-19-2013, 11:01 AM
RE: Philco 40-130T - by Paul Philco322 - 08-24-2013, 09:41 PM
RE: Philco 40-130T - by wireless - 08-27-2013, 05:26 PM
RE: Philco 40-130T - by wireless - 08-29-2013, 03:54 PM
RE: Philco 40-130T - by audiomagnate - 08-29-2013, 08:53 PM
RE: Philco 40-130T - by wireless - 08-29-2013, 09:11 PM
RE: Philco 40-130T - by Paul Philco322 - 09-04-2013, 08:56 PM
RE: Philco 40-130T - by Ron Ramirez - 09-05-2013, 05:42 AM
RE: Philco 40-130T - by audiomagnate - 09-05-2013, 12:20 PM
RE: Philco 40-130T - by wireless - 09-13-2013, 05:41 PM
RE: Philco 40-130T - by Art Hoch - 09-19-2013, 05:58 PM
RE: Philco 40-130T - by Art Hoch - 09-19-2013, 06:00 PM
RE: Philco 40-130T - by Ron Ramirez - 09-19-2013, 07:31 PM
RE: Philco 40-130T - by jerryhawthorne - 09-19-2013, 07:53 PM
RE: Philco 40-130T - by Radioroslyn - 09-19-2013, 10:18 PM
RE: Philco 40-130T - by wireless - 09-21-2013, 05:41 PM
RE: Philco 40-130T - by wireless - 10-03-2013, 01:31 PM
RE: Philco 40-130T - by wireless - 10-04-2013, 05:17 PM
RE: Philco 40-130T - by jerryhawthorne - 10-04-2013, 06:06 PM
RE: Philco 40-130T - by Jamie - 10-04-2013, 06:09 PM
RE: Philco 40-130T - by wireless - 10-04-2013, 06:52 PM
RE: Philco 40-130T - by wireless - 10-06-2013, 05:39 PM
RE: Philco 40-130T - by jerryhawthorne - 10-06-2013, 05:58 PM
RE: Philco 40-130T - by wireless - 10-07-2013, 04:11 PM
RE: Philco 40-130T - by Warren - 10-07-2013, 05:55 PM
RE: Philco 40-130T - by George Kirk - 10-08-2013, 01:44 PM
RE: Philco 40-130T - by wireless - 10-10-2013, 11:07 AM
RE: Philco 40-130T - by wireless - 10-10-2013, 05:44 PM
RE: Philco 40-130T - by George Kirk - 10-10-2013, 07:23 PM
RE: Philco 40-130T - by wireless - 10-23-2013, 02:06 PM
RE: Philco 40-130T - by wireless - 10-23-2013, 03:10 PM
RE: Philco 40-130T - by Jamie - 10-23-2013, 06:16 PM
RE: Philco 40-130T - by jerryhawthorne - 10-23-2013, 07:30 PM
RE: Philco 40-130T - by wireless - 10-23-2013, 10:36 PM
RE: Philco 40-130T - by Arran - 10-23-2013, 11:07 PM
RE: Philco 40-130T - by Chuck Schwark - 10-24-2013, 09:16 AM
RE: Philco 40-130T - by wireless - 10-24-2013, 04:52 PM
RE: Philco 40-130T - by Chuck Schwark - 10-24-2013, 05:32 PM
RE: Philco 40-130T - by Arran - 10-25-2013, 02:17 AM
RE: Philco 40-130T - by wireless - 10-25-2013, 03:03 PM
RE: Philco 40-130T - by wireless - 11-08-2013, 07:12 PM
RE: Philco 40-130T - by wireless - 11-17-2013, 09:19 PM
RE: Philco 40-130T - by BrendaAnnD - 11-18-2013, 02:44 AM
RE: Philco 40-130T - by wireless - 11-18-2013, 12:07 PM
RE: Philco 40-130T - by wireless - 11-23-2013, 08:58 PM
RE: Philco 40-130T - by wireless - 12-04-2013, 01:35 PM
RE: Philco 40-130T - by wireless - 12-13-2013, 10:59 PM
RE: Philco 40-130T - by wireless - 12-22-2013, 05:35 PM
RE: Philco 40-130T - by jerryhawthorne - 12-22-2013, 05:41 PM
RE: Philco 40-130T - by wireless - 12-22-2013, 05:51 PM
RE: Philco 40-130T - by jerryhawthorne - 12-22-2013, 06:39 PM
There are currently 9910 online users. [Complete List]
» 3 Member(s) | 9907 Guest(s)
