Restoration of UK Philco 282 Empire Five
Bottom view of the Philco 282 Empire Five after I finished working on the chassis. Compare this photo to the first under-chassis photo I posted...I think you will see the difference. Icon_smile
(before)
[Image: http://philcoradio.com/images/phorum/282...ive/03.jpg]
(after)
[Image: http://philcoradio.com/images/phorum/282...ive/09.jpg]
RE: Restoration of UK Philco 282 Empire Five - by Ron Ramirez - 08-18-2013, 05:38 PM
There are currently 9662 online users. [Complete List]
» 3 Member(s) | 9659 Guest(s)
