Restoration of UK Philco 282 Empire Five
I found the proper type of dial lamp socket in my stash o'stuff. Unfortunately it was broken and had to be glued back together. Now that the glue is dry, it is ready to be installed in my Philco 282:
[Image: http://philcoradio.com/images/phorum/282...ive/13.jpg]
RE: Restoration of UK Philco 282 Empire Five - by Ron Ramirez - 08-18-2013, 05:41 PM
There are currently 10184 online users. [Complete List]
» 3 Member(s) | 10181 Guest(s)
