Restoration of UK Philco 282 Empire Five
This photo shows where a previous owner cut off the piece of metal that once held the lamp socket for the shadowmeter, and added a different type of lamp socket for use as a makeshift dial lamp holder.
[Image: http://philcoradio.com/images/phorum/282...ive/14.jpg]
RE: Restoration of UK Philco 282 Empire Five - by Ron Ramirez - 08-18-2013, 05:42 PM
There are currently 3680 online users. [Complete List]
» 1 Member(s) | 3679 Guest(s)
