Philco 38-40T
After pursuing this a little further, I realized that if I don't restuff those caps, it will bug me. Not enough to go back and re-do the work, but enough that I will wish I had done it "right"... I've found most of the caps locally, I need to find a few more, and that 6K6G tube, on line. Is 6K6GT a substitute?
I'll be starting in on the caps I have later this week. I won't be able to power up even for a basic voltage check right away because the large power supply cap is one not available local. I figure if I go slow and careful I will successfully remove and replace the caps while looking online for the other parts.
Philco 38-40T - by dustyshoes - 08-12-2013, 12:11 AM
RE: Philco 38-40T - by Arran - 08-12-2013, 05:45 AM
RE: Philco 38-40T - by Jamie - 08-12-2013, 07:41 AM
RE: Philco 38-40T - by dustyshoes - 08-12-2013, 10:28 AM
RE: Philco 38-40T - by dustyshoes - 08-12-2013, 11:29 PM
RE: Philco 38-40T - by Warren - 08-12-2013, 11:48 PM
RE: Philco 38-40T - by Jamie - 08-13-2013, 04:51 AM
RE: Philco 38-40T - by Mondial - 08-13-2013, 09:22 AM
RE: Philco 38-40T - by dustyshoes - 08-13-2013, 11:54 AM
RE: Philco 38-40T - by dustyshoes - 08-19-2013, 08:27 PM
RE: Philco 38-40T - by dustyshoes - 08-28-2013, 09:27 PM
RE: Philco 38-40T - by dustyshoes - 08-28-2013, 09:31 PM
RE: Philco 38-40T - by dustyshoes - 09-20-2013, 08:45 PM
There are currently 5669 online users. [Complete List]
» 2 Member(s) | 5667 Guest(s)
