  • 2 Vote(s) - 5 Average
Philco model 18 (code 121) - HELP!
Jerry,
This time I put the resistance 'jumper' across the two positive points of the e-caps, re-measured the #42 and got nothing. Then I measured from positive e-cap to ground (DC) and got a few big sparks but no voltage measurement (?). Then I measured the #80 tube got a few big sparks again? But no DC voltage reading.
I checked the tubes, they all 'light up' but I know that doesn't mean they work properly and I don't have a tube tester.
I think I'm just going to start taking continuity readings for every connection and highlight on my schematics where I don't get any readings. At least that way I might be able to pinpoint the vacinity of the problem. Not gonna lie, that will take me a while especially since I'm going away this weekend.
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-07-2013, 10:22 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-08-2013, 10:32 PM
RE: Philco model 18 (code 121) - HELP! - by Arran - 02-08-2013, 10:49 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-09-2013, 02:21 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-09-2013, 05:57 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-09-2013, 06:12 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-13-2013, 08:40 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-21-2013, 05:25 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-28-2013, 06:04 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 03-07-2013, 04:16 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 03-07-2013, 11:20 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-17-2013, 01:25 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-18-2013, 08:48 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-18-2013, 09:49 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-29-2013, 10:02 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 06-12-2013, 01:37 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 06-13-2013, 08:33 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 07-23-2013, 10:33 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 07-24-2013, 11:11 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 08-02-2013, 05:06 PM
RE: Philco model 18 (code 121) - HELP! - by Pithicus999 - 08-19-2013, 10:57 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 08-21-2013, 10:26 AM
RE: Philco model 18 (code 121) - HELP! - by morzh - 12-17-2013, 10:58 AM
RE: Philco model 18 (code 121) - HELP! - by morzh - 12-19-2013, 12:47 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 12-19-2013, 08:48 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 01-17-2014, 04:05 PM
Philco 91 Tuning Condenser
