51-932 code 122 change - resistor question
Just received a 51-932 yesterday and it has a code 122 chassis. The schematic I have calls out for a 35Z5 rectifier and 35L6 output. Apparently the code 122 has a 35Y4 rectifier and 50A5 output and is wired as such. There is still a 100 ohm resistor (R5) in the heater string wired into the chassis which I assume was to drop some of the line voltage with the 35L6 version. Being that the output is now a 50A5 is that resistor really still necessary? Thanks in advance!
51-932 code 122 change - resistor question - by TonyJSenior - 02-29-2008, 07:20 AM
[No subject] - by Ron Ramirez - 02-29-2008, 10:41 AM
[No subject] - by TonyJSenior - 02-29-2008, 11:45 AM
[No subject] - by Ron Ramirez - 02-29-2008, 11:50 AM
[No subject] - by TonyJSenior - 02-29-2008, 12:44 PM
[No subject] - by Chuck Schwark - 02-29-2008, 02:45 PM
[No subject] - by TonyJSenior - 02-29-2008, 11:25 PM
[No subject] - by TonyJSenior - 02-29-2008, 11:33 PM
[No subject] - by Ron Ramirez - 03-01-2008, 04:17 PM
