Help on volume pot
Jerry,
Volume control should be Philco p/n 5839, which is a 5K wire wound pot per info on Chuck's site:
http://www.philcorepairbench.com/volctl.htm
Carl
Northern Panhandle, WV
Help on volume pot - by jerryhawthorne - 08-20-2013, 04:51 PM
RE: Help on volume pot - by Bill Kinghorn - 08-20-2013, 06:07 PM
RE: Help on volume pot - by jerryhawthorne - 08-20-2013, 06:17 PM
RE: Help on volume pot - by Carl Travis - 08-20-2013, 06:44 PM
RE: Help on volume pot - by jerryhawthorne - 08-20-2013, 07:36 PM
RE: Help on volume pot - by jerryhawthorne - 08-20-2013, 08:09 PM
RE: Help on volume pot - by Chuck Schwark - 08-21-2013, 09:03 AM
RE: Help on volume pot - by Jamie - 08-21-2013, 04:00 PM
There are currently 9378 online users. [Complete List]
» 1 Member(s) | 9377 Guest(s)
