A 1936/37 Silver 146 "Sylvia" NEW PICS
Update with new pics.
Thanks Jerry! I have seen only a couple of these and figured I couldn't let this go by. Yes, the cabinet needs some work. Looks like a coat of shellac was put on it at some point. The guy I bought it from said it was his great great grandfather's, and it looks pretty much unmolested other than the case.
You are correct, Arran. It is a plant "A" Chicago built radio. Tube line up is: 6A7, 6D6, 75, 43, 25Z5, and K49c ballast. Super het. Here is a link to RM
http://www.radiomuseum.org/r/silver_mfg_146_sylvia.html
Gene
RE: A 1936/37 Silver 146 "Sylvia" - by Arran - 08-21-2013, 12:33 AM
RE: A 1936/37 Silver 146 "Sylvia" NEW PICS - by Gene Pederson - 08-21-2013, 01:50 PM
There are currently 7056 online users. [Complete List]
» 3 Member(s) | 7053 Guest(s)
