41-100 help
Thank you for both your quick replys I knew I came to the right place. I have removed the chassis from the case and began to clean and inspect all the connections and wires the whole battery wire assembly will need to be replaced since all the protective coverings are broken from age. The yellow and black is a antenna is it an external or internal I have seen on some of the old radio pics a metal cage that ran the inside of the radios shell is that something that I should look for? And the battery I seen in Jerrys pic is beautiful, so your hooked the battery to an ac current? what kind of ac are you using and can that work with mine?
Thank you again Brenda and Jerry
Chris
Ps when I figure out how to post picks bigger then 500k ill post mine .
41-100 help - by Steel2040 - 08-21-2013, 12:31 PM
RE: 41-100 help - by BrendaAnnD - 08-21-2013, 03:47 PM
RE: 41-100 help - by jerryhawthorne - 08-21-2013, 05:25 PM
RE: 41-100 help - by Steel2040 - 08-21-2013, 06:02 PM
RE: 41-100 help - by Steel2040 - 08-22-2013, 03:09 PM
RE: 41-100 help - by jerryhawthorne - 08-22-2013, 04:29 PM
RE: 41-100 help - by Steel2040 - 08-25-2013, 07:15 PM
RE: 41-100 help - by Raleigh - 08-28-2013, 02:06 AM
RE: 41-100 help - by EricS - 08-28-2013, 04:44 PM
New member
Philco 630csx power cord
New member
There are currently 3933 online users. [Complete List]
» 2 Member(s) | 3931 Guest(s)
