Tube Question
If you installed a 5Y3 and the radio works, then it was converted to use a 5Y3 by rewiring the rectifier socket.
5Y3 and 5Y4 are electrically identical, but the base connections of each pin are not identical. In other words, a 5Y3 is not a Plug and Play substitute for a 5Y4 and vice versa - the connection to each of the pins differs between the two.
So if it already working with a 5Y3, might as well leave it that way unless you are a stickler for authenticity.
Tube Question - by Jamie - 08-21-2013, 04:13 PM
RE: Tube Question - by Ron Ramirez - 08-21-2013, 08:00 PM
RE: Tube Question - by codefox1 - 08-21-2013, 10:04 PM
RE: Tube Question - by Jamie - 08-21-2013, 10:09 PM
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
Model 27-84 BUZZ?Humm?
There are currently 1587 online users. [Complete List]
» 1 Member(s) | 1586 Guest(s)
