51-932 code 122 change - resistor question
I think I'll leave the output tube as is and not bother with the rewiring required and put a note on the bottom of the radio about the change. If the filament voltages aren't too far off I may leave R5 in place as well. One thing I noticed with this set also is that the pilot doesn't have the initial bright illumination, dimming and gradual brightening as some other typical transformerless AA5 sets I have. This one appears to be off for the most part until the tubes warm up and start conducting - going to take a closer look at the schematic of each later and see if I can figure out what's different with the Philco.
One other question I had and forgot to post earlier. On the print there is a connection from the voice coil to pin 2 on the antenna connector jack and doesn't seem to be carried through at the plug. Any idea what that is for?
[No subject] - by Ron Ramirez - 02-29-2008, 10:41 AM
[No subject] - by TonyJSenior - 02-29-2008, 11:45 AM
[No subject] - by Ron Ramirez - 02-29-2008, 11:50 AM
[No subject] - by TonyJSenior - 02-29-2008, 12:44 PM
[No subject] - by Chuck Schwark - 02-29-2008, 02:45 PM
[No subject] - by TonyJSenior - 02-29-2008, 11:25 PM
[No subject] - by TonyJSenior - 02-29-2008, 11:33 PM
[No subject] - by Ron Ramirez - 03-01-2008, 04:17 PM
There are currently 10231 online users. [Complete List]
» 3 Member(s) | 10228 Guest(s)
