51-932 code 122 change - resistor question
A convenient test point for the service tech to tie his AC meter to the output for aligning. Seen on many post-war Philcos.
Chuck
[No subject] - by Ron Ramirez - 02-29-2008, 10:41 AM
[No subject] - by TonyJSenior - 02-29-2008, 11:45 AM
[No subject] - by Ron Ramirez - 02-29-2008, 11:50 AM
[No subject] - by TonyJSenior - 02-29-2008, 12:44 PM
[No subject] - by Chuck Schwark - 02-29-2008, 02:45 PM
[No subject] - by TonyJSenior - 02-29-2008, 11:25 PM
[No subject] - by TonyJSenior - 02-29-2008, 11:33 PM
[No subject] - by Ron Ramirez - 03-01-2008, 04:17 PM
