41-290 On/Off Switch
That isn't the original switch, the original was riveted to the back of the switch assembly. Unfortunately, this means the original actuator is gone as well.
You can do a workaround by using that bracket someone fabricated for the replacement switch, and installing a small switch from Radio Shack in its place. I do not remember the part number and don't have time to look it up, sorry.
41-290 On/Off Switch - by lenmiller - 08-22-2013, 08:43 PM
RE: 41-290 On/Off Switch - by Ron Ramirez - 08-22-2013, 08:48 PM
RE: 41-290 On/Off Switch - by lenmiller - 08-22-2013, 08:57 PM
RE: 41-290 On/Off Switch - by Ron Ramirez - 08-22-2013, 08:59 PM
RE: 41-290 On/Off Switch - by lenmiller - 08-22-2013, 09:58 PM
RE: 41-290 On/Off Switch - by Ron Ramirez - 08-23-2013, 05:53 AM
RE: 41-290 On/Off Switch - by lenmiller - 08-23-2013, 05:20 PM
RE: 41-290 On/Off Switch - by Ron Ramirez - 08-23-2013, 05:52 PM
RE: 41-290 On/Off Switch - by lenmiller - 08-23-2013, 06:13 PM
RE: 41-290 On/Off Switch - by Raleigh - 08-28-2013, 03:02 AM
RE: 41-290 On/Off Switch - by lenmiller - 08-28-2013, 07:42 PM
New member
Philco 630csx power cord
New member
There are currently 3933 online users. [Complete List]
» 2 Member(s) | 3931 Guest(s)
