Transitone Details
Looking for some history and particulars on the Transitone table models 0f the 40's. They seem to be smaller, well designed yet simple radios.
They could be yet another catagory of Philcos to collect Icon_wink
Transitone Details - by Drew - 03-01-2008, 11:26 AM
[No subject] - by Chuck Schwark - 03-01-2008, 03:34 PM
[No subject] - by Ron Ramirez - 03-01-2008, 04:29 PM
[No subject] - by Drew - 03-01-2008, 05:55 PM
Philco 91 Tuning Condenser
