Transitone Details
Transitone models are very collectable - and are with many collectors.
Have you seen the HISTORY section here on Ron's site?
http://www.philcoradio.com/history/index.htm
Transitone Details - by Drew - 03-01-2008, 11:26 AM
[No subject] - by Chuck Schwark - 03-01-2008, 03:34 PM
[No subject] - by Ron Ramirez - 03-01-2008, 04:29 PM
[No subject] - by Drew - 03-01-2008, 05:55 PM
There are currently 9899 online users. [Complete List]
» 3 Member(s) | 9896 Guest(s)
