Philco 96 Whooped boy
I have to take some more pictures I have glued all the loose joints and veneer which has been time consuming because there was so many loose sections and I only have so many clamps. It appears to be shaping up good but I think in the end I may sand the top and use some filler to fix the bad spots and then use black lacquer on the top. I know some models had black lacquer tops, I'm don't think the 96 highboy is one but hopefully it won't look too out of place.
Philco 96 Whooped boy - by 49Stude63 - 10-20-2005, 10:28 PM
[No subject] - by Chuck Schwark - 10-20-2005, 10:49 PM
[No subject] - by Jerry Huelsbeck - 10-20-2005, 10:54 PM
[No subject] - by 49Stude63 - 10-20-2005, 11:04 PM
[No subject] - by Ron Ramirez - 10-20-2005, 11:27 PM
[No subject] - by 49Stude63 - 10-21-2005, 11:31 PM
[No subject] - by Chuck Schwark - 10-21-2005, 11:42 PM
[No subject] - by 49Stude63 - 11-20-2005, 04:05 PM
[No subject] - by Ron Ramirez - 11-27-2005, 10:13 PM
[No subject] - by Ron Ramirez - 11-29-2005, 06:54 PM
