Transitone Details
Thanks Ron and Chuck - I've passed over a few at our local radio show,but may start buying them if priced right, could make a neat collection.
Also, the Philco history page is well done.
Drew
Transitone Details - by Drew - 03-01-2008, 11:26 AM
[No subject] - by Chuck Schwark - 03-01-2008, 03:34 PM
[No subject] - by Ron Ramirez - 03-01-2008, 04:29 PM
[No subject] - by Drew - 03-01-2008, 05:55 PM
Philco 91 Tuning Condenser
There are currently 10047 online users. [Complete List]
» 1 Member(s) | 10046 Guest(s)
