Philco 118x
Picked this up this weekend. Works well as is but I'm sure a recapping will be in order. Painted a real cheesy white but beginning to flake off and uncover the original finish underneath. On a good note this unit even has the original back in good condition. Should make a good project.
73 de,
Gary/N9VU
Philco 118x - by n9vu - 02-28-2008, 12:04 AM
[No subject] - by Ron Ramirez - 02-28-2008, 12:14 AM
[No subject] - by n9vu - 02-28-2008, 12:20 AM
[No subject] - by n9vu - 03-01-2008, 07:39 PM
[No subject] - by 49Stude63 - 03-04-2008, 10:15 PM
[No subject] - by Fred R - 03-05-2008, 11:14 AM
[No subject] - by n9vu - 03-08-2008, 03:45 PM
There are currently 9298 online users. [Complete List]
» 1 Member(s) | 9297 Guest(s)
